wudao2001
5 years agoNeighbour
- 4 years ago
- Logout
- THANKS ANNA!!!
Deuce
I have the exact same issue...Telus tells me the problem is with Honeywell, the supplier of the device and Honeywell says its related to Telus. Anyone?
Cheapshot_ND
I have the same issue. Both of what Telus and Honeywell is correct. I'm sure it's more on the Telus side. I think their router is picking up the communication to Honeywell as a hacking attempt. The solid yellow light means it's on the network but, it's unable to get to the Honeywell server.
- loyalClient5 years agoCoach
Do you know what the firmware version of the WI-Fi 6 units are? and is there any switch in your environment?
