JujhaarSekhon
6 years agoAdvocate
Not getting speed of my internet plan using ethernet
I have internet 150 with pure fibre and I connected my laptop to Ethernet and I was only getting the average speed of 95 mbps. My laptop supports up to gigabit speeds
- 6 years agoxray the tech opened up a white box in my garage and he told me that some cable was broken so that’s why it I wasn’t getting full speed. Also he was fixing some wires in the panel as well.
BrandonT
TELUS Team Member
6 years agoHi JujhaarSekhon ,
Alright, so with the tests done so far, we now know the wires from the modem to your devices likely not to be an issue since you are able to achieve similar results using WiFi which narrows down what to troubleshoot.
95mbps with 17 active devices is a very good speed.
That means the remaining 16 devices are sharing the remaining speeds of 55mbps (3.4mbps/device).
For safe measure, lets try disconnecting all devices except your laptop so we have a dedicated connection to the maximum speeds.
- Test #1 - WiFi within 5 feet from the modem.
- Test #2 - Ethernet directly to the modem.
- Test #3 - Ethernet from the wall (like you initially had it)
If there are any issues, they should appear with these final tests.
TELUS Employee & Neighbourhood Volunteer :black_small_square: Found this post helpful? Let others know by clicking [❤️ Like] or [Accepted Solution].
JujhaarSekhon
6 years agoAdvocate
BrandonT: I did all the tests and these were the results?
Test:1 5 feet away from modem:
using wifi with only one device using internet:
Upload: 98.4
Test:2 Ethernet directly to modem:
Upload: 94.3
Test:3 test through Ethernet jack:
Upload:92.7
I think modem is not working properly?
Upload: 98.4
Upload: 94.3
Upload:92.7
