DragonDal
4 years agoNeighbour
Not able to enjoy 1.5gb speed internet upgrade
I recently upgraded my internet 1.5gb speed. However it most unfortunate that I use wired connection to my pc, Telus recent hardware does not support anything faster than 1gb wired. Seems like waste,...
- 4 years ago
DragonDal Wrote: Telus wifi hub which is that has 1gb wan port and 4x 1gb lan ports and my pc has a 2 5gb nic I would get 1 5gb speed correct.
I think the simple answer is no. if the Telus hub as you have referred to it, has a 1Gbps WAN port and 4 1Gbps LAN ports, the best you will see is 1Gbps speed throughput on the wireline.
Now if you have Telus equipment capable of either 2.5Gbps WAN and LAN or in the example of the Arcadyan NH20A Router having a fibre WAN connection, and the Capability of 10Gbps LAN port you see the capability of full 1.0Gbps, 1.5Gbps, right up to the 2.5Gbps speeds currently offered by Telus.
DrPacman
4 years agoRockstar
DragonDal Wrote: Telus recent hardware does not support anything faster than 1gb wired.
Actually this is not correct. Telus will support up to a 2.5Gbps hardwired connection to various devices. Now, for this to work correctly you must have compatible hardware throughout the entire connection chain. i.e. the incoming signal in your case must be 1.5gbps and any and all additional hardware must be capable of 1.5Gbps or faster.
You cant have a 1.5Gbps incoming signal, then pass that to a laptop/desktop with a 1gbps NIC interface and expect to get the full 1.5gbps speeds.
There have been a number of threads discussing this topic here on the forum over the last little while. a few are linked here for your reference.
https://forum.telus.com/t5/Internet-Home-Phone/PureFibre-1-5-GB-but-speed-remains-1GB/td-p/131569
https://www.youtube.com/watch?v=gzk69kHLu1o
As well a YouTube video discussing this very subject. Cheers
- DragonDal4 years agoNeighbourHi there,Well so you are saying the with telus wifi hub which is that has 1gb wan port and 4x 1gb lan ports and my pc has a 2 5gb nic I would get 1 5gb speed correct.Warm regards,Holger
- DrPacman4 years agoRockstar
- DragonDal4 years agoNeighbourHi Dr,
Yeah exactly what I thought hence my original post after contacting Telus support and was told that they do not have any hardware that supports anything highrr than 1gb . I have the Arcadyan WiFi hub. So now i am confused . I guess will have to contact them again about upgrading to the Arcadyan NH20A Router having a fibre WAN connection, and the Capability of 10Gbps LAN port
