ewantaylo
4 years agoNeighbour
No connection to anything other than google sites over LAN, but a full connection over wifi- except!
This is for a telus wifi hub router/ modem combo. My wifi works, but my LAN doesn't. Wifi will load anything I want, but a wired connection will only load google services. I've tried with two laptop...
- 4 years ago
Have you played with any setting in the router? If so what? This was from yesterday, has it resolved itself?
What's the model # of the wifi hub router/ modem combo? what is the physical signal path/chain of your present equipment?
Reboot
Factory reset
Physical wiring changes
LAN DHCP static addressing, range setting
MAC address filtering allow/denial list
IP conflicts
etc
ewantaylo
I've had this issue since I got telus internet in mid january. I've reset and factory restored it the router multiple times.
This is all my router info.
Present path is- ethernet line into the wall, and then a cable from the wall port to my PC. I've tried a few cables, and even plugging directly to the router.
I'll try adding my MAC to a whitelist and setting a static address.
The devices connected to the ethernet cables are definietly connected to the internet though- it's just that they can only go to default google sites.
kamak
4 years agoAmbassador
If I'm reading this correctly you're getting "FULL" internet connectivity, but not LAN connectivity when using ethernet?
"No connection to anything other than google sites over LAN"
