Juicebox
9 months agoNeighbour
Modem/Router settings Causing issues with VOIP
So i have the following products NH20A - modem The white cylinder for the WIFI booster. I have been trying to find a setting where I can disable my "SIP ALG" (Application Layer Gateway). Ty...
4 months agoHello. We'll send you a private message, check your Inbox.
Cooter383
3 months agoNeighbour
Hi, I am also having the same issue. I need to Disable the SIPALG settings. I have a BoostLite BE74. I have been able to open UDP Ports 5060-5070, it worked for a couple of days but now it gives me an error code 3004 on my MajicJack
- TELUS_Support3 months ago
Thanks for reaching out. We understand the frustration when SIP ALG or port settings are causing issues with services like MagicJack. Unfortunately, we aren’t able to check or modify SIP ALG settings from here. To get this properly configured and resolve the error code 3004, please connect with our Technical Support team. You can reach them here: support.telus.com/home-expert-sm
