Rocky3
5 months agoGuardian
Loss of audio while lips keep moving!
Audio skips were previously reported and fixed. They are back again. A two second count of lips moving and no sound. This occurs live and recorded, on demand, Prime & Paramount. So basically on any ...
- 5 months ago
This has been happening to me for months and I finally got tech support on the phone. After a TON of trouble shooting that I had already done on my own, they were able to log in remotely and found that the optic terminal coming into the house was alarming several times a day and rebooting itself causing the audio dropouts for up to 5 seconds randomly and intermittently throughout the day. The Optic terminal is a white Nokia box. Tekus is coming on Easter Monday to replace it.
Rocky3
Settings --> Television -->
Are you asking that this be fixed by the TV settings? The TV just parrots what it is given via HDMI
- TELUS_Support5 months ago
The settings above were for your Optik TV box, were you able to give them a try? And failing that, did you try connecting the box directly to your router via LAN cable to see if the issue persists?
- Rocky35 months agoGuardian
I had Lan connected and had the problem. I relocated TV 10 feet, room layout, from WIFI and decided not to run visible extra wires. Surely, 10 feet from WIFI should not cause this problem.
Did I mention it was once fixed. I will also mention I have not noticed bleeps for a week or so.
Telus support tries but these problems elude permanent fixes as tech support does not seem to know what causes them, and then guesses on what to trial and error to repair.
We've flagged it to our product team. If we hear about any substantive updates we can share, we definitely will.
