JeffC
2 years agoFriendly Neighbour
Can I mount my telus cable box behind my tv?
- 2 years agoIf your Optik box has an IR port on the back then all you need is the IR extender cable.
WestCoasterBC
2 years agoCPU Alum
Do you have the new TELUS TV Digital Box, or the technicolor or arris box? If you have the new digital box you can as the remote is bluetooth. If you have the Arris or Technicolor box, the remote requires line of sight. As it's only IR and will not work hidden,.
JeffC
My cable box is an older one, so definitely not the new Android box. I don't see technicolour or Arris marked anywhere on the box either. I guess the question should actually be, what do I need to do to mount the cable box behind the TV & have it function? I did a little internet research & it sounds like I would need an infrared extender cable. Perhaps I should contact Telus & inquire about the Android box.
- xray2 years agoHeroIf your Optik box has an IR port on the back then all you need is the IR extender cable.
