PoCoGuy
2 years agoFriendly Neighbour
Boost WiFi works when wired but not otherwise
I got myself 5 boosters. They’re all setup in my connect app. When all are wired at the same time they’re all blue lights and show as working. When I disconnect the 4 satellite units from Ethernet,...
PoCoGuy
Thanks for the reply.
All the units are side by side, practically touching.
Any other ideas on why half work and half do not?
El-Eric
Community Manager
2 years agoI have two thoughts if they are so close together. It could be interference as they are all trying to broadcast the same network. To test you could unplug them all and begin plugging them in one-by-one.
If the same ones are showing the red light then it could be that the units are faulty and need replacement - that would be a call to our tech support team to have them look at the issue.
