Optikalist
3 years agoFriendly Neighbour
Any tips for better audio quality?
Just wondering if I'm missing a setting somewhere. My audio is terrible, dialogue is difficult to catch often run my sound bar 80 just so I don't need captions, meanwhile background noise and music ar...
Optikalist
So I did grab another remote that's not paired with anything and adjust the volume down and up it seems as if there's no difference at all. It just seems to mute the audio on zero but between 1 and 25, I can't tell a difference thanks for the thought though
WestCoasterBC
3 years agoCPU Alum
What sound bar do you have and what setting is selected on the audio bar dollby surround, stereo etc. I run a Bose sound bar and have no issues.
