Hogan
2 years agoOrganizer
Admin Login to Telus Wifi 6 Access Point & Device wont connect.
So I just got Pure Fibre. Its all hooked up & working well. But I have a problem that a couple of devices only can only connect to the 2.4 (or whatever) bandwidth. So my research has told me that sup...
Darren_P
You need to login to the WiFi Booster, not the Fibre Hub.
The ip for mine is 192.168.1.15
The hub is 192.168.1.254
Serge-E
12 months agoHelpful Neighbour
Thank you for the hint.
In my case it was .42 for the WiFi6 router.
I used an App called who is on my network. I had my phone on the Telus SSID, nothing else connected to this SSID, aside from the 2x Boosters and my laptop. Easy to find the target IP to login.
