edmiidz
8 months agoOrganizer
TELUS Mobility Conditional Call Forwarding Codes Stopped Working
Hi all, I’m trying to determine if others are seeing the same issue. I rely on TELUS Mobility conditional call forwarding using GSM codes: *61*<forwarding number>*<timeout># – forward when una...
edmiidz
All three forwarding options are failing – *61, *62, and *67.
For *61 (Forward When Unanswered), we tested multiple timeout values including 15, 20, and 30 seconds. None of them forwarded; the calls still route directly to TELUS Mobility voicemail.
This worked earlier yesterday and then stopped around 8 PM PST with no device changes on our side.
8 months agoGotcha. We'll send you a private message to discuss further.
