SMOKESKULL
3 years agoFriendly Neighbour
5G speed poor. Worse than LTE+ on Koodo
I just switched to Telus 50GB unlimited and my speeds on 5G are slower than I had on Koodo. I called tech support and it was elevated 2 levels and I was told the service in my area for 5G was poor. I...
SMOKESKULL
I have an S23 Ultra. It can get 650Mbs using wifi on a gigabit connection. I tested the speeds as I approached the tower array situated on a peak within the city. The speed only got worse the closer I got. I made sure the towers were in clear view each time.
George22
3 years agoNeighbour
Am planning to switch from koodo to telus , if somebody have advice which one is better regarding signal , speed ,etc.. i have s23 ultra
- SMOKESKULL3 years agoFriendly NeighbourIf your in a big city and close to the 5g towers you can expect good results. I am in Kamloops and 5G service here is 4G branded as 5G which I think is very misleading. If your paying for 5G you should expect service faster than 4G LTE+
Good luck
