Mathsss
3 years agoOrganizer
5G / LTE B71 (600 MHz) Montreal
Hi,is it normal that there is 600 MHz antennas liste in the database of a tower near me in the east of Montreal not powered? Additionally I am not seeing them with the app I have on my S20 5G. Powerin...
Syaoran
3 years agoAll-Star
What makes you think those antennas and spectrum licenses are owned by Telus? The Telus network primarily uses band 66/n66 for their service from coast to coast. Definitely not the best choice and then there are some areas where only Bell towers exist that are also used by Telus. Bell and Telus do not own any band 71/n71 spectrum.
Mathsss
Hi Yes they have in Quebec and for Montreal. Not in GTA
https://ised-isde.canada.ca/site/spectrum-management-telecommunications/en/spectrum-allocation/auctions/auction-spectrum-licences-600-mhz-band/600-mhz-auction-final-results
If you use Tower locator app on Android you can see the towers and if you click on the tower you have the list of antennas / power
Just switch to Telus and disappointed on ly B2 and B7 are often used. B12 or B13 are barely used. My only hope is the 600 MHz n71 in LTE mode. I think they wait before enabling. Can't see n78 I have a S20 that I think not compatible but useless inside a building.
- Syaoran3 years agoAll-StarInteresting. That doesn't mean they intend to deploy it though. Usually small allocations of spectrum are used to barter for other chunks of spectrum owned by other carriers that is more comparable with their already deployed technologies.
- Mathsss3 years agoOrganizerAt the price they buy yhe licenae for sure they will use it but did noy seen any until now
I hope they use it but Rogers and Videotron are good candidates to trade or sell that spectrum to for a profit. Telus has been very profitable over the past few years at customers expense. Band 66/n66 isn't bad outside in mostly flat areas that aren't heavily populated so band 71 deployment would help Telus a lot in the major cities. I just don't think that they intend to deploy it because it does not fit into their current deployed technology. The Telus network is about as basic as it comes.
- Mathsss3 years agoOrganizerI hope so because even if I get a good plan I will either go back to Rogers network or will try Videotron network
