Dashpuppy's avatar
Dashpuppy
6 years ago
Solved
Home Fiber Connection _ Ip keeps changing every few days.
Why does the lease time on the Telus Fiber connections have to be so low ? My ip address keeps changing every few days. I work from home and have multiple vpn connections for work & the phone system for work. Ipsec tunnels have to have the IP manually entered in and its VERY frustrating that the ip keeps changing so often.
  • Check your router. It sounds like it may not be properly renewing the DHCP leases in time. Normally an IP change is rather infrequent, at least using the Telus gateway.
  • Nighthawk's avatar
    Are you using the Telus provided router or your own?
    • Dashpuppy's avatar
      Dashpuppy
      My own router, I run a Untangle Firewall because i have Multiple Ipsec Tunnels for work. Weird, my ip just changed AGAIN !!  in 2 days it's changed 4 times.
