a month ago
Sometimes you’re watching a show and you pause for a moment to have a close look at something in the picture. Problem is, the progress bar, title of the show and all of the option buttons come up and never disappear.
Most other operating systems, these things will appear for a few seconds and then fade away, allowing you to see the entire screen. You know, pause isn’t just for getting up to refill your drink bud. Sometimes you have to try and read the fine print that is always at the BOTTOM of the screen.
a month ago
When you're paused, press the Back arrow (just above the Volume button) and the overlay will disappear.
a month ago
We have been having all kinds of problem with our boxes for the past week and a half. It stoped controlling the TV and our stereo. We can’t get it to turn on, we have to unplug and plug it back in. It’s locked up while using the guide a couple of times and needed to by unplugged. I’m assuming there was an update that may have some bugs to work out?
