Optik DVR problems?!?(maybe)
Zman2k2
Leader
So I’ve been having some issues with our DVR as of late.  What happens is after you turn it on, after about 20 min. you will get freezing picture/audio, A/V dropouts which come back within 15 seconds, and the dreaded “This channel has been lost” screen, which resolves within 30 seconds.  It all comes back, with no intervention, only to do it again after 5 minutes or so.
im asking the group, is there something I can do to resolve this ( I have done reboots, resets )., or am I going to need to be on hold for a while to fix this.  As well, has the Optik system been “sundowned” so that i would be switched to the new system?
Appreciate the answers.
Well a bunch of time on the line, and errors on Telus’ end after every reboot, it has been determined……. dying PVR.  Not a bad service record, almost 15 years.  I hope it has a happy retirement. 😀
4 REPLIES 4
Is the DVR connected by ethernet? Is it going through an ethernet switch by any chance?
If you find a post useful, please give the author a "Kudo" or mark as an accepted solution if it solves your trouble. 🙂
No, not through a switch.  Made that mistake years ago.  It’s is wired directly to the NH20T.
Glad you were able to get it sorted with our team. Please let us know if you experience any further issues your service once the new equipment is up and running!
Type a product name
