TELUS Recording issues since June (Arris PVR box)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
12-15-2023 09:18 PM
Been having an issue with the Arris Telus PVR Box for an issue that began earlier this year in June 2023 and has been continuing up to this point, There has been a recording issue where sometimes a recording that you press fast forward on stops and says recording finished on the screen when you aren't even halfway done watching a recording (ex. a 3 hour Hockey or football game recording will end at the 55 minute mark when fast forwarding). I have also seen that these kind of recordings that end early also stutter when pressing the skip ahead 30 seconds button, meaning they will freeze and play and freeze again every few seconds. This has also impacted the future recordings that have been set on the same PVR box as I have noticed the box will not record future programs that were scheduled to record over a week ago even though it shows in the scheduled space. (A recording set for 7 pm to 7:30 pm shows in the scheduled recording tab but does not record at 7 pm and stays in the scheduled tab until the time of the program has ended at 7:30 with nothing ends up being recorded). I have done the reset of the Telus system in the order Telus states (Restarting the modem by unplugging/replugging then unplugging the PVR and then the other digital boxes). The problem usually ends up resolving after doing that process but then the same issue comes back again a week or so later so I need to restart everything again. And the following weeks the same process again. This issue has been going on since June 2023 till now and I hadnt had this issue at all before June ever since I switched from Shaw to Telus in 2018 and was given the same PVR, Modem and Digital boxes that I still use 5 years later. Has anyone else experienced an issue like this with their PVR this year and does Telus know of this being an issue?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-16-2023 04:49 PM
It sounds like the hard drive may be failing. if that's the case all that can be done is to replace the box.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-30-2023 09:22 PM
We have been having a constant issue identical to yours.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-02-2024 02:56 PM
Hi @KJaswal & @kharasym, I concur with @FuzzyLogic that you may want to call in to have the box replaced!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
a week ago
I have the same issues, sometimes only recording a part, and sometimes all recording stops.
I have had remote diagnostics, a tech visit, and the box replaced. But eventually the problem appeared again.
In the past I had some success with deleting all recordings, delete all schedules (individual and series), and reboot the box. That used to solve it for many months. But recently recording stops again after a week or two.
I am right now going through another cycle of replacing the boxes (Arris VIP5662W). Not a pleasant experience.
