Wireless optik box
PennyB
My wireless optik box has suddenly lost its wifi connection. I just keep getting the one me then two gear display. Other devices (ps3) have no issue with connection so it’s not the wifi range. Will hitting the pairing button fix it? Will that disrupt my wifi boosters? Thanks!
1 REPLY 1
FuzzyLogic
Sounds similar to this:
Solved: Optik TV wireless box shows gear Icon and progress... - TELUS Neighbourhood
I hope it helps
