PVR recording doesn't work
Reply
EdC
When I try to record a show, the first time I press "Record Episode", nothing happens. Then when I try to press anything else on the remote, it says "PVR system is busy. Try again later" and is only fixable by restarting the TV box
Accepted Solutions
Most Helpful
Reboot the Actiontec first, then reboot the PVR. Once it's booted up, reboot any remaining set top boxes.
All Replies
Most Helpful
