Will my phone work on the telus network?
ZeroRequiem
It is called the umidigi plusE.  It has these network specs:
GSM: 850(B5)/900(B8)/1800(B3)/1900(B2)
WCDMA: 850(B5)/900(B8)/1900(B2)/2100(B1)
LTE FDD: 2100(B1)/1800(B3)/2600(B7)/800(B20)
I am also interested in knowing if the UMIDIGI Z Pro Helio will work.  It has these network specs:
GSM 850(B5)/900(B8)/1800(B3)/1900(B2)
WCDMA 900(B8)/2100(B1)
LTE FDD 2100(B1)/1800(B3)/2600(B7)/800(B20)
Has anyone tried using one of these on the telus network?
Thank you for any assistance you can provide
This article describes the Telus Network, and should be of help to you.
TELUS deploys HSPA: 850 and 1900 MHz; LTE: 700, and 1700/2100 (B4), and some 2600 MHz, so it should work on 3G, but not LTE.
2 REPLIES 2
PlusE
3G: It's possible. B2/B5 should work but no guarantees. You'll be limited to 3G speeds if it does work.
LTE: No.
Z Pro. > No. This will not work in Canada on 3G or LTE.
A good number of phones imported from Asia will not work in Canada. Especially the lower cost ones since manufacturers often have to use a different chipset for it to work in North America.
