Trackpad not working properly
Reply
Jules0408
Resident
I have a BB Curve 9360 and the past couple of days I have noticed that my trackpad does not 'click' instantly. If I have to open a BBM or text, or even just select something I have to push the button a couple of times before it will open. I've done a battery pull and even updated my software, still no luck. Any ideas or will I have to take my phone in?
Most Helpful
adaml
Connector
If you've reloaded the OS with no change, then it unfortunately sounds like a hardware issue.
