Samsung Note N900W8
Reply
GANT1994
Just got this thing, was typing an SMS then hit something and all get now is the S Pen, how do I get my alpha keyboard back???????
SuperFred
Moderator
Moderator
Hi, it's hard to give you the right answer without having a similar device but do you have any keyboard logo keys somewhere? Can you search inside your settings, controls and you'll probably find the options there. Search Google with the exact device model you have and you should find your answer.
