March
Good afternoon
I just received a Samsung Galaxy Tab A7 Lite and am trying to put the sim card into the tray. It seems like the card is too wide for the tray. Any other users have that same problem?
Thanks
March - last edited March
Are you using your old sim from another device if so what device? Or a new sim card? Pay attention to the notch position as well on the tray and card.
March
March
March
The new sim card is a multi sim and you can select the size by bending off the selected size you need.
March
The single tray should have two positions , one positions fits the sim and the other a memory card.
March
March
March
