Phone plan
Shancb
Whats the best phone plan or option of a pre teen.
6 REPLIES 6
FuzzyLogic
So many options. Without more information it's hard to make a recommendation.
This is one of many sites that can help you shop for a plan based on your requirements:
Best Cell Phone Plans in Canada - Find the Cheapest Prices - PlanHub
No data. Only wifi as im worried he will go over his data. Calling and texting. Currently doesnt have a phone. So need a phone also. Hes 11
@Shancb  Cheapest phone you can find. Low end plan with data shut off. Screens are not cheap to replace.  Best do it at a store so they can make sure data is off ...
Thank you
FuzzyLogic
If you only want talk and text here are the offerings from Telus:
Cell Phones Canada - Shop $0 Smartphone Deals & Plans | TELUS
Prepaid. You know exactly how much will be spent, and the child CANNOT overdraw the account. They can learn to add top-ups from a retail store if they want extra.
