03-22-2015 12:52 AM
Hi everyone,
I was just curious if it was possible to 'special order' the 64gb version of the Nexus 6.
I have a lot of photos and music and 32gb is just not enough for me.
Thanks in advance for your help!
03-22-2015 03:07 AM
If you want a phone not offered, the best option is to get it directly from the supplier. Special orders likely do not exist because the carrier does not have the phone available for delivery.
03-22-2015 03:07 AM
04-02-2015 01:19 PM
How much storage one should get is always a consideration when choosing a smartphone. My advice would be to consider complimenting your Android with some cloud storage. Photos and Music can be stored on-line and accessed from your device at all times without using up vast amounts of local storage. Think of it as a large memory card accessible on-line.
Of course, data consumption (mobile data) is a consideration but most cloud services offer a "off-line" mode.
Good luck in your decision!
04-02-2015 03:44 PM
Use Google drive for photo's..
