Looking for info about switching phones from Rogers to Telus
Reply
Highlighted
Resident
I have a fairly new Samsung s4 and want to get it unlocked to use on my Telus network. What the processing?
Highlighted
You must contact Rogers to unlock your phone (for a fee), or use a 3rd party unlocking service. Once unlocked and you've purchased a Telus SIM card. You can then activate it on the Telus network with a plan you choose. (Pending approval)
http://www.telus.com/en/bc/mobility/plans/?&cmp=KNC_MOB_Google_&SEM_CID=158398323&SEM_KW...
Highlighted
If it's locked to Rogers currently, you'll have to get them to unlock it. Once done all you'll need is a Telus SIM card and a plan. 🙂
For information on unlocking with Rogers, please see their page here. I believe the unlock fee gets waived December 1st (all carriers).
Highlighted
TELUS Employee
TELUS Employee
The bring your own device plans are listed here:
http://www.telus.com/en/on/mobility/plans/?linktype=nav#byod
Just make sure in the top right hand corner you have the correct province selected as that will impact the plan pricing.
You can also bring your current Roger's phone number over to Telus by getting your Roger's account or security pin. Do not cancel the Roger's account. When you create the Telus account, you give them your Roger's phone number and either the account number or security pin and they can bring that phone number over. You will have mixed service between Roger's and Telus for up to 2 hours. Meaning you may be missing calls or unable to dial out in that period. Once you receive a text saying that your Port is completed. Then you will have service 100% on Telus and all your services will be working.
Mobility Client Care Rep
Highlighted
Resident
Thanks
Highlighted
Ambassador
If you can wait until December, the CRTC has mandated that unlocking must be provided free. Save yourself $50.
