Is the Razer phone work with Telus network?
bmwm
   Hi,I want to buy the Razer phone  https://www.razerzone.com/ca-en/mobile/razer-phone
But I am not sure is this phone work with Telus network, e.g( like the call , Lte.....)
The phone bands
  • GSM: Quad-band GSM UMTS: B1/2/3/4/5/8
  • LTE: B1/2/3/4/5/7/8/12/17/19/20/25/26/28/29/30/66
  • TDD LTE: B38/39/40/41 TD-SCDMA: B34/39
And this phone is missing the B13. So I don't sure that this Razer phone will work with Telus network.
Thank you!
It'll work. It's their Canadian website as well.
Telus doesn't use band 13. LTE is typically band 4. 3G is 2 and 5.
https://forum.telus.com/t5/Mobility/Will-my-phone-work-on-the-TELUS-network/ta-p/53882
http://willmyphonework.net/
3 REPLIES 3
Ok
Thank you very much.
It's a great phone!  Good choice!  You won't have any compatibility issues with that at all and it will work on all Canadian and most US carriers.
