Going to Republic Dominican
Reply
Highlighted
Resident
Wil my iphone 4 work while I am there or is there a plan I can buy that will cost me less to call home in Canada
Accepted Solutions
Highlighted
Most Helpful
CPU Alum
CPU Alum
Check out the travel passes for the Dominican Republic...
http://www.telus.com/wireless/travel/index.jsp?zone=caribbean&country=Dominican Republic#travel-pass...
If you are a heavy user (need more than 300mb).... you might want to have your phone unlocked and then getting a SIM once you arrive.  Then again, not all international SIMs allow you to call Canada without a long distance phone card.
You might want to consider something like Skype to keep in contact with friends back home.  With public wifi... seriously consider installing a VPN to minimize data eavesdropping.
http://www.youtube.com/watch?v=Ti8Kpev1Abc
All Replies
Highlighted
Most Helpful
CPU Alum
CPU Alum
