Email problems
joncask
okay here's the deal..
Blackberry Curve 8530... when I went to setup my email on my phone it got set up as an "enterprise" type and I was wondering if there
was anyway to change it to my personal use and it is not giving my the option to even change accounts all it's doing
is saying "your email is set up as enterprise.. click finish"
HELP! 🙂
2 ACCEPTED SOLUTIONS
Hi Dimo-X
I did a wipe/restore last night and it didn't give me the option to reset up my email.. which is kinda weird..
I tried figuring out how to do that.. but I didn't have any luck.. like I don't even have the option to chose an email acount because
the enterprise got set up
4 REPLIES 4
Dimo-X
Moderator
Moderator
Hi Joncask,
You will need to wipe/restore your device (backup beforehand if necessary) and then re-setup your email, at which point it will give you the option to set it up as a personal email as opposed to enterprise.
Cheers! 🙂
Hi Dimo-X
SuperFred
Moderator
Moderator
Hi, I think you'll need to have the BES remove from your mobile account in order to have a regular bberry service.
