port forwarding nightmare need genius help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-06-2023 03:22 PM
Hello - hoping for a resident genius to help with port forwarding on FXA5000.
Recently moved, in the old house the same model, FXA5000 had port forwarding/mapping with plex and rdp working correctly and ports open confirmed via portcheckers.com. Windows firewall has the correct rules. Source IP was 172.218.-.-
After moving however, the ports remain closed, added the same port mapping in the new hub and restarted. yet it stayed closed. telus installer revisited twice and actually changed the hub 3 times over various issues (telus phone not working) Also connecting the NAS server to the hub itself doesn't work either.
In trying to troubleshoot, have tried to add firewall rules to the hub, but interestingly the public ip address isn't in a range that the firewall accepts. I wonder if that IP assigned to me might have something to do with not being accessible. could be natted / CGNAT - new IP is 23.17.-.-
Any help is greatly appreciated!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-07-2023 03:19 AM
@thejudge wrote:Hello - hoping for a resident genius to help with port forwarding on FXA5000.
Hello,
I see your post
Please follow below
It seems that the change of location and the new Telus hub may have introduced some complications with port forwarding and accessing your NAS server. It's possible that the new IP address assigned to you is using Carrier-Grade NAT (CGNAT), which can restrict external access. To troubleshoot, consider reaching out to your internet service provider (Telus) to confirm if CGNAT is in use and discuss the possibility of obtaining a public IP address. Additionally, ensure that your port forwarding settings are configured correctly on the new hub and that any necessary firewall rules are in place.
Thanks and regards
Allensolomon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-12-2023 06:09 PM
Thanks for the reply - spent all weekend with Telus and a new router as well - they tried everything but the IP address won't change. Then I tried putting the NAH into bridgemode and connecting the router, i get wifi access but anything LAN doesn't. not sure why, will try to troubleshoot more this weekend. Hopefully someone else has some ideas
