Telus wifi Hub booster issue
Pennys
I am using the new Telus hub modem not the t3200. When I had boosters with my old modem, the wifi boosters had their own wifi signal which I had to log in. But when I set it up with this, it tells me to remove the rj45 cable and setup the next booster. Both are online and visible in the telus wifi app, but I can find their wifi connection under my wifi.
0 REPLIES 0
