T3200 wifi device block
Kacob
Hi,
To limit my kid’s wifi access, I created a couple of family profiles and set up schedules for each child. When the scheduled wifi ban is on, my kids now bypass it by logging in as a “new device”.
I saw a post where a parent only allows guest wifi and shuts it down manually. aside from this tactic, is there another solution?
1 REPLY 1
You could definitely check in with our Tech Support team to see if they have any further recommendations other than the Guest WiFi option.
Type a product name
