Internet from SAC to House Problem
fredmb
My copper drop from the Telus ped to my NIC is spliced and gets wet, so I lost my internet connection and get poor TV.
Telus has tried different pairs but the problem still comes back.
I have heard Telus can use my coax from the ped to my NIC, is this correct?  How do I get this service?
2 REPLIES 2
Telus doesn't own the exterior coax so no they can't use it. The only coax that's occasionally used is inside the house itself.
They'll most likely need to run a new line to your house.
If you find a post useful, please give the author a "Kudo" or mark as an accepted solution if it solves your trouble. 🙂
rc
Rockstar
You are going to have to call telus repair and report your problem as a chronic problem and ask them to escalate repair to cable maintenance.
