Deekay3884
9 months agoOrganizer
El-Eric
Community Manager
3 months agoHi Deekay3884 - no ghosting here. I did send an email to the team that was helping provide us with updates and they confirmed that there has been acoustic enclosures installed and some major repairs are under way.
Deekay3884
3 months agoOrganizer
Hi El-Eric, thanks for the reply. I've been running my fan non-stop to try and cancel out the noise so I hadn't noticed the change from the acoustic enclosures earlier. I just turned my fan off and yes, the noise is around 50% less than before, so the enclosures are helping, that's good to know.
The last update we received on the timeline for full resolution of the upgrades was given on July 14th where we were told it would be a couple months to finish the work. Since we're past that point now, would it be possible to get another timeline update from the team?
- El-Eric3 months ago
Community Manager
Glad to hear that the noise is better. We did ask for an update on the timeline so I am waiting on that but once I know more I will definitely let you know!
- Deekay38843 months agoOrganizer
Thank you!
- Annex3 months agoHelpful Neighbour
Hi Deekay3884,
thank you for bring this back on the burner and thank you El-Eric for the response.
I have noticed that the sound is a bit more muffled but it is definitely still causing disruption. The by-law office has indicated that this concern filed months ago is now 4th in line for investigation. Looking forward to this resolving amicably soon.
