GillyW
4 years agoNeighbour
WIFI/internet connectivity issues in the evenings - keep on having to renew DHCP lease as a fix
I am loosing connectivity to my wifi constantly and keep on having to renew the DHCP lease as a fix. When I look at the available WIFI networks around me there are many strong Telus signals (I live ...
- 4 years ago
If you can connect another device with ether et to see, it would be helpful.
I experienced a similar issue years ago (pre Optik), and the issue was the copper line at the street - it was in a wet underground cabinet. Switching to a different pair by the Telus Tech fixed it.
You'll need to do a bit more surveillance of your connection to narrow it down, as I can't see renewing the DHCP as fixing a Wi-Fi issue.
4 years agoAre you losing Wi-Fi connectivity, or Internet connectivity? Do ethernet connected devices remain connected when you lose connectivity, or all devices? Usually renewing a DHCP lease would indicate an internet problem not a Wi-Fi problem. It may mean a line quality issue, especially if you are on a copper connection.
Are you on copper or fibre?
GillyW
I am on copper - it seems to only be on WIFI (although the only ethernet connect device I have is my Optic TV - no disruption in Netflix/Amazon Prime)
- NFtoBC4 years ago
- GillyW4 years agoNeighbour
Okay thanks for the suggestion.
I thought it may be a Apple thing (because all of my devices are Apple) .
Then I thought it may be the apartment upstairs from me - when they are home and trying to get onto their telus wifi - there may be congestion.
Because last night they were not home and I had great connectivity.
As you mention - there are alot of variables - if I were to call Telus out to come take a look do you think they can help me?
- NFtoBC4 years ago
"if I were to call Telus out to come take a look do you think they can help me?"
You will need to do some of the research I suggested first. If you suspect congestion, hardwire as much as possible, as there is rally no better solution.
