RonAKA
6 years agoRockstar
- 6 years agoIs Smart Steering turned on? If so try turning it off. You will need to create a separate SSID for each WiFi band (2.4 GHz and 5 GHz) so keep the SSID for the band used by the most devices and create a new SSID for the other band.
6 years agoHero
Do you have any non-Apple devices? Are you experiencing dropout on those?
Hogan
6 years agoOrganizer
Yeah, all i know is this. The problem is only with my 2 iPhones & 1 iPad. Not with TV's, laptops ...etc. Wifi connection shows very strong on phone, but will have trouble/wont connect on occasion. Wheel is spinning. What "fixes" it very temporarily is switching to another wifi channel, turning wifi off/on or turning phone off/on. Me knowing nothing and using my powers of deduction thinks the modem/router does not like the iPhone
Related Content
- 3.5KViews8Comments
