RonAKA
6 years agoRockstar
- 6 years agoIs Smart Steering turned on? If so try turning it off. You will need to create a separate SSID for each WiFi band (2.4 GHz and 5 GHz) so keep the SSID for the band used by the most devices and create a new SSID for the other band.
RonAKA
6 years agoRockstar
What do you think about manually setting a fixed IP address assigned to the iPhone MAC address?
RonAKA
6 years agoRockstar
I switched to a fixed IP for my iPhone. It worked for about 3 hours yesterday. It now does not work about 2.5 hours after signing in this morning. Not a solution.
Related Content
- 3.5KViews8Comments
