RonAKA
7 years agoRockstar
- 7 years agoIs Smart Steering turned on? If so try turning it off. You will need to create a separate SSID for each WiFi band (2.4 GHz and 5 GHz) so keep the SSID for the band used by the most devices and create a new SSID for the other band.
6 years agoHero
So it sounds like there is an issue with the OS layer not reading the state of the WiFi connection properly from the hardware layer. I don't own any Apple products so I'm just guessing here but is there any power saving features on the iPhone that may be turning off WiFi and not turning it back on properly?
RonAKA
6 years agoRockstar
What do you think about manually setting a fixed IP address assigned to the iPhone MAC address?
- RonAKA6 years agoRockstar
I switched to a fixed IP for my iPhone. It worked for about 3 hours yesterday. It now does not work about 2.5 hours after signing in this morning. Not a solution.
Related Content
- 3.4KViews8Comments
