RonAKA
6 years agoRockstar
- 6 years agoIs Smart Steering turned on? If so try turning it off. You will need to create a separate SSID for each WiFi band (2.4 GHz and 5 GHz) so keep the SSID for the band used by the most devices and create a new SSID for the other band.
RonAKA
6 years agoRockstar
I guess I am wondering what happens when I Disable SmartSteering. What will I be presented with for options?
WestCoasterBC
6 years agoCPU Alum
You will simply then have two SSID with your network name. (what ever you network name is) 5ghz and 2.4ghz. Some devices you may have to re-enter a password but should not have to. Only if you want to connect to the newly created SSID. TV side will not be effected making the change.
Related Content
- 3.5KViews8Comments
