Bruce88
5 years agoNeighbour
Wifi Connection Issues
So I am a new Telus user who decided to get the 1giga bit plan. The internet works amazing on my gaming devices since i have them connected via ethernet cable. Issue is with the Wifi connection. I am...
- 5 years ago
Are you running IOS 14? There are reported issues with this and wi-fi.
Quickly disable/enable wi-fi on your phone if you are experiencing issues seems to be the quickest way to resolve this.
Jeanette47
I'm interested in what disadvantages are of splitting into 2.4 and 5
Having difficulty with combined in connecting smart bulbs
RonAKA
5 years agoRockstar
I only use a T3200M modem and have no hubs. In the T3200M you can disable the smart steering which uses both bands and set up two individual bands with a different SSID. With each wireless device you decide which band you sign it into. The 2.4G has more range but potentially less separation on the channels for lower throughput. The 5G has better separation and capacity, but less range.
Not sure what the implication is of having hubs. Have no experience.
