Yatsukin
6 years agoFriendly Neighbour
WiFi Boost and Ethernet
Hi everyone, I've just set up my two Wifi Boost sets, and I'm wondering whether the original one needs to stay connected to the router through the ethernet cable, or whether I can remove it and p...
- 6 years agoYou need the first boost to be connected by Ethernet to the router. The boost units run their own mesh network separate from the WiFi the router runs. You should disable the WiFi on the router to avoid interference and signal congestion.
6 years agoHero
Yatsukin Look here to identify your router.
https://www.telus.com/en/ab/support/interstitial/troubleshoot-boost-wifi-actiontec-t3200m
Yatsukin
Looks like the Arcadyan router is white. Mine's black, so going by the link xray showed, I better just keep the first booster connected to the router.
Oh well!
