RonD
1 year agoNeighbour
Volume Control
Using an Optik TV-21T box with a Monitor type TV, so no tuner and no internal speakers, HDMI cable hook up Monitor has optical audio out but its fixed not variable same as the Telus box's optical...
- 1 year ago
Hi RonD , this is outside of our support, but perhaps you can try the following to see if it will work:
1. Hold Input and Left on the DPad for 3 Seconds
2. LED on remote should be solid green
3. Press OK
4. LED on remote should blink white, green, white, green
That command locks the volume control to the STB
RonD
1 year agoNeighbour
No, I haven't got thru to tech support yet
From other posts in this forum, and my experience with my other regular TVs, as soon as you program the remote for a TV brand/model the remote's volume buttons default to that TV brands IR commands, so no longer sends Telus box volume up/down commands
I doubt many people would ever run into this issue, most would be using IR controlled Home Theater Amplifier with a Monitor type TV, and that can be programmed
But didn't see an Optik code to reset volume back to Optik box while leaving the TV on/off as is
Optik-Kate
TELUS Team Member
1 year agoHi RonD , this is outside of our support, but perhaps you can try the following to see if it will work:
3. Press OK
