rupin's avatar
rupin
1 year ago
Solved
Using Wifi Hub or T3200 as AP
Hi there. I have both a T3200 and the round trash can wifi hub. My Nokia modem is in my basement but wifi upstairs is terrible, and I'd like to be able to stream from my xbox via remote play. I don't...
  • Nighthawk's avatar
    1 year ago
    This has been asked several times recently. No the T3200 and the Wifi Hub cannot operate as APs. They will function as routers and there is no way to change that. If you did try use it as an AP, it would end up having double NAT and the Xbox will not be happy with that. You're better off just buying an AP. They're not that expensive if you go with Wifi 5. One example is only $40. The Wifi 6 version is $90.
