jbooth's avatar
jbooth
3 years ago
Solved
Using IR remote on Optic TV STB
Hello, I have a Telus Optic TV box model # VIP5662W I'm trying to get a universal remote working with this device, it's a Sofabaton U1 that supports IR but not Bluetooth. Is this possible? I found...
  • WestCoasterBC's avatar
    3 years ago
    If the remote supports it, there should be IR learning where you can point the telus remote at the Sofabaton and manually capture the ir functions.
