J_Y117
4 years agoOrganizer
Upgraded Smart Hub Question
Hey All, For anyone who has the new 5G Smart Hub, can anyone say whether the hardware supports a bridge mode? I currently have the old LTE hub and I'm considering upgrading to take advantage of t...
kamak
4 years agoAmbassador
Well I'm sure you can get everything you want without bridging. Just in case you can't do it with the device they give you, whatever that is, an ONT/Router/WiFi Hub. What is it you think or know that you are going to benefit from by using your own router as the actual WAN side to WLAN/LAN as a singular device? The New Telus Hubs and ONTs are all 2.5Gbe
I personally was looking to try to future proof (within reason) my new home's Network/WiFi, by getting a 10Gbe x 2.5Gbe multiport POE switch and some 2.5Gbe APs, but that's it, I'll use the Telus ONT and or Router/Hub as the WAN side as long as I can connect to it/them with the 2,5Gbe port from either one of them as need be. I have no know reason or need to use my own ONT/Router for the WAN side.
4 years agoKamak, what does an ONT / Wifi Hub / fibre etc. have to do with a cellular Smart Hub? The OP specifically mentioned "LTE hub" and "5G Smart Hub". It has nothing to do with fibre.
- kamak4 years agoAmbassador
Wow dude, you got some attitude don't you? What's your beef? You can't even give you a Kudo here and there and you're all over me like stink on @#$@#. Did you even read the OP's request? He wants to bridge a router to the router that would come with a 5G modem setup. Really nothing to do with the modem 5G side of it. I gave him my advice about router bridging and AP and not to or to do bridging. Do you even read the entire threads? Am I stepping on your realm of Telus Community Forum domination. Suck it.
5G modems come with WiFi/Routers for in home networking, you know that right?
First and foremost did you even give the OP some words of wisdom thy lord?
