bskitmor
2 years agoAdvisor
TP-Link Deco AX3000 WiFi 6 Mesh System
Thinking of replacing my existing T3200M router plus 3 Arcadyan extenders with a TP-Link Mesh system. My wifi network has been showing some flakiness of late and I'm thinking it's time to move on. ...
- 2 years agoYes, should be a straight swap. I recommend duplicating the same SSID and password with the new router so you don't need to reconfigure any of your devices.
bskitmor
2 years agoAdvisor
Good question -- I didn't even get as far as configuring the Ubiquiti because I couldn't get a required Internet connection to run the setup utility. And, you are quite right I should have received an Ip address other than 192.168.1.1 -- it's kind of like a catch 22. Maybe it's possible to do some offline config work on the Ubiquiti and check that it's DHCP capable. Something else I did today was to connect the NOKIA Opt ethernet "out" directly to the Ubiquiti WAN port (after recycling the OPT) -- no difference, same inability to get into the Ubiquiti setup process and in this case no DHCP dimension (presumably). I am getting terminally impatient -- can't understand how Ubiquiti gets such great press (e.g. Garmin) and an almost evangelical following.
Thanks for your help
2 years agoHero
Did you try a hard reset on the Ubiquity? I would think the default config is to use DHCP
And you are welcome. It's easy helping people who are willing to do the work to help themselves.
Related Content
Using a TP-Link router / AXE75, Android boxes, which settings do you change
I'm going to get the new android boxes instead of iptv boxes and fully-bridge my tp-link AXE75 from the NAH, do you guys have any settings on or off that aren't default to make it work? And, if I rem...Solved3.7KViews5Comments
