bskitmor
2 years agoAdvisor
TP-Link Deco AX3000 WiFi 6 Mesh System
Thinking of replacing my existing T3200M router plus 3 Arcadyan extenders with a TP-Link Mesh system. My wifi network has been showing some flakiness of late and I'm thinking it's time to move on. ...
- 2 years agoYes, should be a straight swap. I recommend duplicating the same SSID and password with the new router so you don't need to reconfigure any of your devices.
bskitmor
2 years agoAdvisor
I have tried pinging from the Windows command line without success. The bridging just seems to be inoperative. I am trying to send to router back to Ubiquiti (most disappointing) -- in the meantime I have upgraded my Purefibre to 1.5gb. Maybe a fresh start will lead somewhere positive.
2 years agoHero
Any device connected to the LAN side any router won't be able to ping the WAN IP of said router. That's how network routing is supposed to behave.
It just occurred to me that if the T3200M is in bridge mode the Ubiquity should not be getting 192.168.1.1 as the WAN IP. It should be getting a public IP. Are you sure the Ubiquity is configured to use DHCP?
- bskitmor2 years agoAdvisor
Good question -- I didn't even get as far as configuring the Ubiquiti because I couldn't get a required Internet connection to run the setup utility. And, you are quite right I should have received an Ip address other than 192.168.1.1 -- it's kind of like a catch 22. Maybe it's possible to do some offline config work on the Ubiquiti and check that it's DHCP capable. Something else I did today was to connect the NOKIA Opt ethernet "out" directly to the Ubiquiti WAN port (after recycling the OPT) -- no difference, same inability to get into the Ubiquiti setup process and in this case no DHCP dimension (presumably). I am getting terminally impatient -- can't understand how Ubiquiti gets such great press (e.g. Garmin) and an almost evangelical following.
Thanks for your help
- xray2 years agoHero
Did you try a hard reset on the Ubiquity? I would think the default config is to use DHCP
And you are welcome. It's easy helping people who are willing to do the work to help themselves.
Finally got the Ubiquiti UDR connected to my home network using 3200m bridging after installing the UDR software offline using a connected laptop. Eureka!
Related Content
Using a TP-Link router / AXE75, Android boxes, which settings do you change
I'm going to get the new android boxes instead of iptv boxes and fully-bridge my tp-link AXE75 from the NAH, do you guys have any settings on or off that aren't default to make it work? And, if I rem...Solved3.7KViews5Comments
