dave_z
5 years agoNeighbour
Telus Hub (Arcadyan) remote access/management
Hello, I'm trying to access my Telus WiFi Hub (Arcadyan router) remotely with port forwarding. I can see that there is a router IP and a gateway IP. When I enter the router IP locally it goes to ...
- 5 years ago
As far as I know remote access to the router admin pages is blocked in firmware. The only way around it that I can think of is if you can remotely access one of the PCs on your network and log in that way.
Is there a reason that you need to remotely access the settings? Normally once they're configured the first time, it's rare to ever need to log in to change settings afterwards. Many settings are under the Telus My Wi-Fi app now also, which can be used remotely.
5 years agoAs far as I know remote access to the router admin pages is blocked in firmware. The only way around it that I can think of is if you can remotely access one of the PCs on your network and log in that way.
