ArneSalvesen
6 years agoNeighbour
FirasM
I'll add my name to the chorus here - over 30 devices in the home, all phones and laptops are Apple. See the same issue staying connected to a 5Ghz network.
Same as Jammer005, I've turned off 5Ghz on the modem and left on the 2.4 for older smart devices that operate on 2.4Ghz (the boost 2.4Ghz network doesn't work with those devices). It looked like it was working for a few days, then saw the problem again.
I contacted Telus a few times, and one of the agents actually helpfully gave me the IP address to futz around with the Boost network settings (similar to model settings). The modem URL is 192.168.1.254 and the boost URL is 192.168.1.68. The admin password is on the boost itself (note there are two passwords there). I was initially very excited about this, but realized later that it's NOT POSSIBLE to turn off 2.4Ghz networks on the Boosts! I couldn't believe it...
Starting to think this is an Apple issue rather than a Telus problem. At the very least the issue seems to be restricted to macOS and iOS.
Anyway, long story short: a tech came today couldn't solve the problem, called his supervisor and he said there's a known issue with Apple products and the Boosts. They're waiting for an update for the boost.
Interim solution/workaround is to provide me with a wireless extender until the issue is resolved.
thought it might help ...
FirasM
Update FYI: there was a firmware update for the Boost devices (v1.32.28) on Nov. 13.
This update was released BEFORE the technician arrived but hey it might take time for this info to trickle through the chain.
The agent claimed that it should update by itself upon a restart (blinking purple light) but that didn't work for me. Calling in right now to get them to do it, hopefully this helps you all solve this.
I have a good feeling about this...
- NFtoBC5 years ago
- adrockwe5 years agoHelpful Neighbour
- NFtoBC5 years ago
- NFtoBC5 years ago
- Nighthawk5 years ago
- Powderjockey5 years agoAdvocate
- BC_EZ5 years agoOrganizer
- NFtoBC5 years ago
- NFtoBC5 years ago
- BC_EZ6 years agoOrganizer
Yes, I'm using the T3200M as well. most of my devices are connected to it instead of the Boost as there seemed to be too many problems staying connected. I was thinking of changing routers as well.
I was thinking of going to this one, https://www.staples.ca/products/317890-en-asus-rt-ac68u-dual-band-ac1900-wi-fi-gigabit-router as I've got one at work and it just flat out works.
So my problem is solved... finally had the T3200M replaced with the Arcadyan, which meshes with the boosts. (Actually replaced it because could not get it to go over 350Mb when I was on 750.) Have not had the dropping issues since. Also seems to better handle the IoT devices that can't jump frequencies.
Anyway - not sure if we confirmed this, but are all of you on T3200s?
Same issue - Apple devices 'forget' the password on Boosts... Interestingly, not all at once. You can move to another corner of the house (where another Boost is working) and connect fine.
So the workaround I have right now:
- T3200M is on a daily reboot schedule - I needed this before the Boosts came into the picture anyway, as the wifi sometimes gets flaky midway through the day. This is still true.
- T3200M SSIDs are both (2.4, 5) hidden, and Smart Steering is off. Need this for older IoT devices, and for a backup when the main (Boost) wifi fails. It's often better, but as I said, can be flaky too.
- 2 of my 4 Boosts (I blame the ductwork in the house for the dead zones) are now on daily reboots (cheap mechanical timers). We'll see if the others eventually need them too.
It's far from perfect, and numerous tech visits didn't help - they seem really resistant to replacing the T3200M. Each time they come by, they reset it, and "prove" to me that its behaving fine. Whatevs.
- WifiFrustration6 years agoNeighbour
My boosters have this update and its all still no good. I get asked to enter my wifi password on Macbook Pro and iPhone XR every day. Telus has no answers for me. Time to switch providers?
I haven't been able to my Boosters to upgrade to the new firmware. Perhaps I will have to call Telus and see if they have a way to push the new firmware to my Boosters.
- DGO6 years agoNeighbour
Did this get resolved with the firmware? How did you get the new firmware?
