jjdinks
3 years agoFriendly Neighbour
- 3 years ago
jjdinks
so ethernet cable from ONT to T3200 right so that I get Gigabit from the T3200?
No adapters needed right?
And to once again confirm, I will need to make this cable run myself?
3 years agoHero
Yes, the cheapest solution is to run an Ethernet cable from the ONT to the T3200M WAN port. If logistics are too complicated for doing that (walls and floors) then next cheapest option is Nighthawk suggestion of using MoCA adapters if you have an existing coax (cable) run. Third choice is PowerLine adapters that use the house power wiring.
